I have an automatic C6 and the shifter on the column doesn't work. The shifter was moved to the floor prior to the truck becoming mine. I bought a donor truck that I was able to get a bunch of goodies from. The donor truck has a manual transmission and the shifter on the column works real nice.
I was wondering if I swapped steering columns from the donor and installed it onto mine, would the shifter on the column work? The old linkage in mine is still hanging there to hook back up. By all appearances, the steering columns look identical, from the steering wheel to the rag joint.
Does anybody know if this will work?
Ken
72' F250 Custom 2wd 360 C6 auto
99' GMC 1 ton dually flatbed 454
07' Ford Ranger 2wd 4.0 Sport
