Is the hole threaded for shoulder harness?
- Kurt Combs
I am thinking about three point seat belts, but I thought I heard somewhere that the holes behind the rubber plug in the B pillar isn't threaded from the factory. Anyone know if the hole in 72 F-250 would be threaded? Of course if I wasn't a lazy old guy I suppose I could pull the plug and look.......just didn't want to pry it out if I should decide to stick with the lap belts.
Kurt
1972 F-250
1972 F-250
- robroy
Re: Is the hole threaded for shoulder harness?
Good evening Kurt,
They weren't threaded on mine. The adventures I endured to put three-point seat belts in my '72 F250 are documented here: May I ask for advice on Beam's 140" WSCH300 seat belts?
Robroy
Robroy
- Tpdaniels
In my 72 the holes were NOT threaded, I used the shoulder mounting bolts from a late 70's Ford car to mount my shoulder belts. the bolts were self tapping, I took my 1/2 air hammer and ran them in, then back out, them mounted the belt's. It worked like a charm and only took a few minutes to do both sides.Kurt Combs wrote:I heard somewhere that the holes behind the rubber plug in the B pillar isn't threaded from the factory. Anyone know if the hole in 72 F-250 would be threaded?
I am of an age now that most of life's lessons were learned the hard way;
Life is hard, but it’s harder when you’re stupid.
Never approach a bull from the front, a horse from the rear or a fool from any direction.
Never ask how stupid someone is 'cause they'll turn around and show you.
Light travels faster than sound. This is why some people appear bright until you hear them speak.
If you had the choice “Looks or Brains” take the Brains, Looks will get you thru the first half, but Brains will last a lifetime.
- Calfdemon
My 72 had one hole threaded, and one wasnt... My 69 has 3 threaded and 1 that isnt... I am thinking they were SUPPOSED to be threaded, but it was one of those corners that the assembly line worker could cut and never get called on because no one was running shoulder belts back then. So the answer is that yours may or may not be threaded...
-Rich
Current toys -
Former toys -
Current toys -
Former toys -
- mcheath
Mine weren't. Was easy to tap threads, but was surprising that they were unthreaded.
- Kurt Combs
Thanks for the replies, I'll plan on tapping the holes out when I install belts.
Kurt
1972 F-250
1972 F-250
Mine were threaded in my '70 F-250. I understand some are and some aren't. My retractable seat belt install was a piece of cake.
My 69 had both of 'em threaded.
they're threaded in the 70 cab on my truck right now
they were also threaded in the (previous)68 merc cab and original 69 cab
running a tap through em is a good plan,the threads in the 70 cab were pretty crusty
- colnago
So, for those who have converted to the shoulder harness, do you like it, hate it, so-so, ... ? Just curious; I haven't decided which way to go yet.
Joseph
Joseph
- Calfdemon
Just knowing that my head wont fly forward and hit that wheel and dash if I get in a wreck makes me feel all warm and fuzzy inside. So for safety's sake, I love it.
-Rich
Current toys -
Former toys -
Current toys -
Former toys -
i like having the shoulder belt,i dont slide around on the seat nearly as much when i'm driving like a psychopath and i no longer have to explain that the truck only came with lapbelts when officer friendly decides to stop me for a chat either .
I swear the factory buckets i have are upholstered with teflon or something,they're at least 3 times as slippery as the heavy duty vinyl bench i used to have - nearly killed myself hopping into the thing a couple of times now and have actually slid right off the seat while doing a quick road test after doing some ignition and carb work
- feefie
My 70's are threaded. I am not crazy about impailing myself on the steering column in a head on.....thousands in dental work too so steering wheels dont need to be on my dining menu. I will be converting over to them soon, need some money to buy them after market. I drive my old bump between 8,000 - 10,000 miles per year...... About to go put some new tires on her. Firestone transforce makes a 9.00 x 16.5 tire in a 10 ply. Gonna give them a try and stay with original rims for a few more years.
sv
sv
Doing what is right isn't always easy....doing what is easy isn't always right.
1968 Mercury M-250 clone
1976 F-250 Highboy
1976 F-250 Highboy
- 91Bear
Mine in my '69 were threaded.
Yeah, but without headrests your old noggin will fly backwards and hit the back window. That (and the gas tank behind the seat) makes me nervous.Just knowing that my head wont fly forward and hit that wheel and dash if I get in a wreck makes me feel all warm and fuzzy inside. So for safety's sake, I love it.
- abyars111
All 4 holes on my '70 crew cab were threaded. I installed 4 shoulder harnesses for me and my family. It was a breeze to install.
Anthony
1970 F250 Crew Cab 2wd 390/2v short bed
2004 Eddie Bauer Expedition
1955 Chevy 210 4dr Sedan
