Seatbelt pics needed
Zukinut
Post by Zukinut »
Putting three points in my truck. I've read all the post on here but so far haven't found a picture of where all three points are mounted.
Any help greatly appreciated.
Will
toddspeed
Re: Seatbelt pics needed
Post by toddspeed »
I was about to order them as well from LMC - I'm not happy with the upper mounting location on the back of the C pillar (I have a 1970) but there's not exactly another option. Those mounts are behind the black rubber plugs beside the rear window. The lower mounts simply use the 2-point mounts from the lap belts.
Was there a truck that used 3 point belts that might have take-off parts? Or did the F100 even come with them in later years?
Todd in Atlanta
1970 F100 Ranger born the same month/year as me - 360 C6 2WD, P/S, LWB
You! Yes You! Please put your location in your profile - it helps us help you when it comes to parts, pricing, and advice.
Zukinut
Post by Zukinut »
With the aftermarket three points there are three points but only 2 holes. The aftermarket belts have the retracting part that bolts in, the shoulder hook part and a third loop with a bolt hole.
Where does that third loop bolt too?
Will
toddspeed
Post by toddspeed »
Same place on the floor the other end of the lap belt bolted to - towards the middle of the cab in front of the gas tank. I believe the aftermarket belts come with a L bracket to get a better angle.
Todd in Atlanta
toddspeed
Post by toddspeed »
Check out this thread with pics for some help:
Todd in Atlanta
Zukinut
Post by Zukinut »
Todd,
Where in Atl are you located? I'm in lilburn but the shop is in Decatur.
Will
toddspeed
Post by toddspeed »
I live in Decatur. What shop?
Ran into a guy today that just bought a 68...but he lives up in Roswell.
Todd in Atlanta
Zukinut
Post by Zukinut »
Ever heard of Acc Toyota or smoking gun powder coating. It's in Scottdale. We'll have to grab a beer and talk trucks sometime.
Will
toddspeed
Post by toddspeed »
I'm not too far from there - so is there a shop in Scottdale that is doing work on your truck or is that where you work?
Todd in Atlanta
Zukinut
Post by Zukinut »
Worked there for almost 4 years. The truck spent almost a year there as I was rebuilding it. All of my spare parts are stored there etc. I've done some work on a guys '70 in clarkston. It's Probably the cleanest original bump I've ever seen. To be honest I've probably seen your truck if you drive it much.
Will
toddspeed
Post by toddspeed »
Cool - well I've only had it 4 days so it hasn't been around long. What kind of work do you do? I have a bunch of stuff I'm working on and might need to farm a few things out.
Todd in Atlanta
