Hey guys,
I'm planning on taking the center section out of my 9" and giving the internals a good cleaning. Can anybody think of a reason why spraying brake cleaner or carburetor cleanor would damage anything inside, like a seal or anything?
Thanks,
Brandon
9" internal cleaning
- bbyrnes1
Brandon Byrnes
1969 F100, 240 C.I., C4 tranny, 2WD SWB
Re: 9" internal cleaning
Have at it wont hurt a thing
I did the same thing to my dodge and it worked like a charm. Hit it hard, let it drain into a waste bin, then hit it some more. I used almost a whole can. Wear goggles and gloves, the cleaner will splatter all over the place and back into your face from hitting the gears in the differential.
- bbyrnes1
Thanks guys.
Just don't want to damage a seal or anything since I'm not planning on taking the components apart. I learned the hard way by ruining an accelerator pump cup that rubber o-rings and solvents don't mix.
Brandon
Brandon
Brandon Byrnes
