Steeringwheel problem.
amazonsport
Post by amazonsport »
I have a -72 Ford F250, and I wonder if it is normal that the steering wheel is turned to the driver's door a little bit? When you sit behind the wheel, it is about 2-3 cm closer to the dashboard beside the door.
I can not find any adjustment under the dashboard? Is there any?
Living in Sweden, so if you think my English is poor, it is therefore..
Ford F250 -72 390 C6
Volvo 142 -68 B18 four on the floor
Volvo Amazon 121 B20 four on the floor
Honda hornet 900 -02
Harley sportster -06
Yamaha xj 900 -85
Kawasaki 200 Enduro -95
bluef250
Re: Steeringwheel problem.
Post by bluef250 »
Yes, the steering wheel is angled. Right side is a bit closer to the dash than the left side.
91Bear
Post by 91Bear »
That's the opposite of what amazonsport was saying.
amazonsport
Yes, it sounds like you're saying the opposite bluef250.
It feels strange to run like this but a thought I have is that it may have been so when you stepped into the car and has pulled in using the wheel? Could it be?
Yamaha xj 900 -85
bluef250
Post by bluef250 »
I looked at the diagrams again, I am mistaken. The steering is angled. The LEFT side is closer than the RIGHT side. Sorry for the bad information. See - http://www.fordification.com/tech/images/bb70/p04.gif
amazonsport
Thank you very much bluef250, then I know that my car is as it should ..
Yamaha xj 900 -85
