Heater core for sale
Private parties only. No eBay/Craigslist listings.
72 brownie
Post by 72 brownie »
I have a heater core for sale
measures 6"X9" with a distance of 3.5" between the tubes
asking $30.00
Riverside CA
'72 F250 4x2
'68 F250 4x2
'69 F250 Highboy "The Turd"
fireguywtc
Re: Heater core for sale
Post by fireguywtc »
I am not sure what that is for but it does not go to any factory bumpside systems. It looks like an a heater core for a intergrated AC setup but factory AC heater cores have a 6" core. They are about 9" long total.
Bill
1970 F-250 4x4 highboy ranger 390 V8, 4spd
2012 F-350 PSD FX4 LWB CC lariat, white
http://www.fordification.com/galleries/ ... hp?uid=602
"If you want to judge a person's true character, give them power."
72 brownie
was ordered from LMC as a heater core W/AC for a 72 pickup. Unable to return, i figured maybe it was for a later year truck, or maybe car? in any case that is why i put the dimensions up so yall could see for your self.
'72 F250 4x2
'68 F250 4x2
fireguywtc
I had the same problem with LMC but I was able to return the heater core right away. They claimed that it is the proper part# and crosses from another vehicle but I can't remember which one. I am sure LMC is aware of the problem but continue to advertise and sell the same core that does not fit any factory AC system. Sorry you can't return it.
Bill
72 brownie
Yea I figured maybe someone else might be able to use it, looks like it will sit around in the garage for awhile and find its way on an unintended project.
'72 F250 4x2
'68 F250 4x2
fireguywtc
I don't know if you have intergral AC in your truck but here is what I am doing right now for my 70. The heater core from a non-ac heater uses the same size core as the AC one, just has different tubes. The one on that core has the correct end tank and tubes for the AC setup, just the core is too long. You can buy a new non-AC heater core and have the end tank swapped onto the non-AC heater core to make a new AC heater core. I am doing that right now, dropped off the two cores at the radiator shop this afternoon.
Bill
