Any ideas?
BlueovalFE
Any ideas?
Post by BlueovalFE »
I want to change the rear end gearing on my '69. Currently has a 3:50 and I want to go with something like a 3:00 or maybe a 3"08. Other than a ring and pinion gear, what else will be required to swap it out?
sargentrs
Re: Any ideas?
Post by sargentrs »
As long as you're in there, might as well put new bearings, seals, etc if you plan on keeping her awhile. That's assuming you haven't recently. When I did mine u bought a kit with everything in it for around $130.
SoCalExile
Re: Any ideas?
Post by SoCalExile »
Too bad I'm not still in TX, I'd trade you my 2.93-3.00 rear for yours. :doh:
BlueovalFE
Re: Any ideas?
sargentrs wrote:As long as you're in there, might as well put new bearings, seals, etc if you plan on keeping her awhile. That's assuming you haven't recently. When I did mine u bought a kit with everything in it for around $130.
Yeah, I will. I've had this old relic too long and spent too much time and money to get rid of it now. Wish I could post a picture of it but I'm having a hard time with it.
cep62
Re: Any ideas?
Post by cep62 »
BlueovalFE wrote:Yeah, I will. I've had this old relic too long and spent too much time and money to get rid of it now.
If you're on a budget you could put in a used center section from an old LTD.
They usually had around a 2:78 ratio and weren't abused too much.
As long as the axle splines are the same (28 or31) and a nine inch they'll interchange .
You'll probably have to change the yoke.
They aren't a performance rearend so it should be less than $100. ($50)?
BlueovalFE
Re: Any ideas?
Thanks cep
