Defrost vents
- la1031
Defrost vents
I have a new dash and an a/c kit from factory air. Looks like the defrost vent adapters attach to a factory part that is held in the dash with 2 screws. My new dash did not include the part and I dont see it on LMC's catalog. Anyone have one or can send me a picture so i can head to the scrap yard?
http://s446.beta.photobucket.com/user/1968F100/library/
1968 F100 Shortbed
302/306 roller, C6 w/shift kit
3.70POSI w/trackbars
Hydro-Boost
Hoping for 13's and looking good doing it !!
Makita Industrial Power Tools
Tools for the long run.
1968 F100 Shortbed
Hydro-Boost
- sargentrs
Re: Defrost vents
Check out this diagram http://www.fordification.com/tech/image ... heater.jpg The cover plates don't have an adapter on them. The hose had a flange built into it, I think. It was inserted from the top of the dash and the cover plate held it in place. You're looking for the hose itself and if you don't have them, cover plates. If the windshield is still in, take a "stubby" Philips head screwdriver with you. Clearance at the windshield is limited.
Re: Defrost vents
I believe they're only screwed in on non padded dashes,
padded covers have the grilles built in.
(Correct me if I'm wrong it's been a long time since I took one apart.)
- la1031
Re: Defrost vents
The dash has the vents on it for sure. But there must be a cone shaped piece that my defrost hose attaches to. That is the piece that i am missing. I am headed to the junk yard I guess to see.
1968 F100 Shortbed
Hydro-Boost
1968 F100 Shortbed
Hydro-Boost
- la1031
Re: Defrost vents
Just got back from the junk. The original defrost vent hoses have a thick rubber grommet that wedges into the holes in the dash. I cut them off existing hoses on a couple trucks and now I will adapt to my install kit. Mystery solved!
1968 F100 Shortbed
Hydro-Boost
1968 F100 Shortbed
Hydro-Boost
