Hi,
1971 F250 Sport Custom.
What do these buttons do??
- tbone6
Re: What do these buttons do?
The second pic (one above the brake release) looks like a brake pressure differential warning light. First pic, no clue...
t6
1972 F100
1972 F100
- Subzero
Tbone is correct about the warning light. The first picture one is probably a previous owner mod as I don't think these trucks came with buttons like that. If your truck has a cargo light that's normally where a pull out knob would be to turn it on. If you do have the light that button may have turn it on or something.
Thanks!! I havent gotten under the dash yet to trace wires but at least I have an idea now.
- tbone6
I am thinking it is something owner installed, here is the position for a stock cargo light switch. Notice the distance between the emergency flasher switch... Maybe a starter button or something?
t6
1972 F100
1972 F100
- colnago
My guess is that it's a dash-mounted horn button, 'cuz the one on the steering wheel doesn't work. I've seen them mounted on the bottom of the dash before, where the sheet metal turns horizontal, so the button is facing down.
Joseph
Joseph
- sargentrs
I've got one of those "options". Plan on fixing it right when I get my new steering wheel.colnago wrote:My guess is that it's a dash-mounted horn button, 'cuz the one on the steering wheel doesn't work. I've seen them mounted on the bottom of the dash before, where the sheet metal turns horizontal, so the button is facing down.
Joseph
- huskerrush
exactly where my horn button is.colnago wrote:My guess is that it's a dash-mounted horn button, 'cuz the one on the steering wheel doesn't work. I've seen them mounted on the bottom of the dash before, where the sheet metal turns horizontal, so the button is facing down.
Joseph
You can fight without ever winning, but never win without a fight.
a lot less cheezy than hoseclamping it to the column..colnago wrote:My guess is that it's a dash-mounted horn button, 'cuz the one on the steering wheel doesn't work. I've seen them mounted on the bottom of the dash before, where the sheet metal turns horizontal, so the button is facing down.
Joseph
