I am assuming that this is not what the end of the shifter is supposed to look like.. Somebody told me that the shifter was hardened steel, that it is round at the end like a ball joint, and that it does not deform.. However, as seen in the picture, it appears worn out. The shifter would bind and not pull back. PO's had also cracked the shift collar at some point.
I've searched locally, and cannot find a junked manual column. Carolina Classics did not have any, and they are not reproduced. Before I start a country-wide search, does anybody have a comparison photo of a shifter or can compare and verify that this one is toast? Any insight is appreciated.
