trans linkage
jimmy828
trans linkage
Post by jimmy828 »
when installing the 3 speed column shift linkage, where do i position the levers that are on the trans to have it in neutral ? I know that i need to align the levers on the column shaft but not sure about the trans. Thanks!!
sargentrs
Re: trans linkage
Post by sargentrs »
You can feel neutral when you shift those levers by hand. Each one has 3 positions. The center position on both is neutral. Set them both to center at the same time and you'll be there.
jimmy828
Re: trans linkage
Post by jimmy828 »
sargentrs wrote:You can feel neutral when you shift those levers by hand. Each one has 3 positions. The center position on both is neutral. Set them both to center at the same time and you'll be there.
Thanks Sarge. I thought that was the case but needed to make sure.
