It occurred to me that some inexpensive LED flashlights could be ganged together to make a decent, 12 volt work light. I have two of these:
http://www.harborfreight.com/led-flashl ... 69065.html
When I switch both on and hold them side by side, the result is pretty impressive. Adding a third flashlight would make it even better. AND, because they use 3 AAA batteries, their operating voltage is very likely 4.5 volts. AND, three times 4.5 is 13.5 - Get my drift? By eliminating the batteries and wiring the three flashlights in series, you would have a work light that could be clipped to the battery terminals or plugged into a lighter socket. If you added a simple frame or other means to mount and aim the light, you'd be all set.
The three lights would cost under $5. Best part would be No Batteries Required.
Anyone tried anything like this?
DIY LED Work Light
DIY LED Work Light
Bill
68 F100 Ranger
73 F100 Ranger XLT
Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in garages. (Apologies to Kenneth Grahame.)
68 F100 Ranger
73 F100 Ranger XLT
