1969 f100 Restomod
Show us your rides or projects!
gasnoil
1969 f100 Restomod
Post by gasnoil »
10 months of weekend work ...now enjoying my summer making it rumble down the street.
gasnoil
Re: 1969 f100 Resto Mod
Post by gasnoil »
[/attachment]
MAK
Post by MAK »
Very nice work! :thup:
Texarado
Post by Texarado »
Looks good man, mighty fine work. What all did you do to it?
gasnoil
Post by gasnoil »
Texarado wrote:Looks good man, mighty fine work. What all did you do to it?
thanks Texarado :fr:
here is link :
http://www.fordification.com/forum/view ... 22&t=78152
gasnoil
Post by gasnoil »
MAK wrote:Very nice work! :thup:
Thanks MAK :fr:
XABN82
Post by XABN82 »
Looks sweeet
travis6370
Re: 1969 f100 Restomod
Post by travis6370 »
Those Dodge 20's bolt up just fine or did you have to get spacers ?
Old Greener
Post by Old Greener »
Nice truk, and really like those rims...curious what they look like on a bump when they are chrome? Looking for something to put on my Ranger XLT, that's otherwise stock.
1971 Ranger XLT, 390 auto, longbox, boxwood/seafoam, dealer a/c....a Texas beauty now living the dream north of the border.
gasnoil
Post by gasnoil »
travis6370 wrote:Those Dodge 20's bolt up just fine or did you have to get spacers ?
Hi travis6370, sorry for taking so long in replying.
The bolt pattern is same so they bolt on,however, you will need long shank lug nuts to make up for the thickness of the Ram wheels and lack of length of the Ford stud.
I only needed the long shank lugs in the front.I used 2 inch spacers for the rear to get the correct look.Spacers had long enough studs and thinner wall.
When on a budget, the Ram wheels do the trick for cheap. Got mine for 400.
Hope this helps.
:fr:
gasnoil
Post by gasnoil »
Oh, forgot to mention, you will need to grind/ream the centre of the wheels to fit over front hubs. Don't worry just the plastic tabs will do the trick. Then cover with the AR Torque Trust caps or something else...
Cheers
gasnoil
Post by gasnoil »
Old Greener wrote:Nice truk, and really like those rims...curious what they look like on a bump when they are chrome? Looking for something to put on my Ranger XLT, that's otherwise stock.
Hi Old Greener, thanks for the comments. Mine had some scratches , got them cheap, so ended up spraying gun metal grey with flat clear coat.
A few things to take note of if you want to fit on a bumpside will be.
1. Long shank lug nuts or longer studs
2. Grind center to fit over front hubs. (You will then need center caps unless you want the hub to stick out.)
gasnoil
Post by gasnoil »
