I have a 67 f250 with a cruise-o-matic transmission. What would it entail to swap to a C6?
Transmission swap
- Canonman67
Re: Transmission swap
What engine do you have? Was it ever available with a C6? If it was you just need to find a C6 with that bolt pattern, find the right linkage, maybe a flex plate, you might need to change the column and maybe a trans crossmember or move the one you have. There's probably another 100 fiddly little things that I've forgotten but that's the major part of the work. Let us know how you get on.
