Info on driveshaft
spartman
Info on driveshaft
Post by spartman »
I was thinking about putting a 4 speed in my truck.
I have the tranny and it looks like it is either a T-18 or a T-98.
The housing on top says T-98 but according to my sources it could be either one underneath.
Anyway does anybody have, or know any info on a driveshaft for the short wheelbase trucks?
Any help would be greatly appreciated here.
Jake11
re: Info on driveshaft
Post by Jake11 »
Good choice. Junkyard. Or get one built. 8)
T98 and T18 are about the same. T19 has a synchro for 1st.
You'll like 1st gear. You can pull houses over! :)
spartman
Post by spartman »
How much should one expect to pay for one out of a junkyard?
The closest ones to me in town don't carry anything that old and the one pick and pull I could check isn't open until after the snow melts and the ground firms up again.
ALSO what are the specs of the driveshaft? IE how long, how big around?
If I get one made I want to have some factory specs to compare to.
Thanks guys
flyboy2610
Post by flyboy2610 »
I won't be using the driveshaft out of my truck, which has a T18. It is a two piece driveshaft. You could probably have the rear section shortened, unless the shortbeds used a 1 piece shaft
Let me know if you're interested.
spartman
Post by spartman »
How much do you want for it?
How bout shipping to 57201?
flyboy2610
How about $20? Plus $15 for the shifter from the other post?
I'll have to pull the driveshaft to get a weight for shipping, that may be a couple days.
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
Shortbeds do use a one-piece driveshaft with a slip-yoke in the transmission.
flyboy2610
Yea, I kind of suspected that might be the case.
spartman
Post by spartman »
The tranny I have came from a long bed and doesn't have the slip on end.
mrung0wa
Post by mrung0wa »
If you have a custom one (driveshaft) made FYI: Remember the strength of the driveshaft is in it's diameter (tubing), not in it's thickness (gauge). :cents:
Lawrence 8)
http://www.fordification.com/galleries/ ... ?pos=-2746
FOR SALE: 64 Galaxie 390HiPo C6 (Project Car)
SOLD! 69 F100 Contractor SPECIAL 300 I6 "Jethro"
01 BMW 325i 4DR E46(Wife's car)
03 EXPEDITION XLT FX4(2WD/AWD/4WD) 5.4L K&N FipK
"I beat my head against the wall, Because it feels good when I stop."
