97 rear end in 77
Bunkerhillbilly
97 rear end in 77
Post by Bunkerhillbilly »
I've found a 3:55 disc posi in a local bone yard. Will it bolt into my 77 or will I have to move the spring pads??
akguy09
Re: 97 rear end in 77
Post by akguy09 »
it's definitely not a bolt in affair
Bunkerhillbilly
So I got to move the spring pads? I've done that on rear ends before.
ThinLizzy13
Post by ThinLizzy13 »
What kind of rearend?
I would think a '97 axle width will be different, and the lugs will be metric.
'63 F100 Uni 223 3OT
'67 F250 CS 352 4Spd
Bunkerhillbilly
It's a 8.8 in a 97 F150. Far as I know wheel bolt pattern the same
ThinLizzy13
97 was the first year for metric bolt pattern in F150's. Perhaps you could just swap the axles for the non metrics?
Bunkerhillbilly
Then I would have to redrill the rotors. Back to plan A! LOL! Good ol 9 inch! Can't go wrong with that!
