High tranny tunnel
High tranny tunnel
I have a '67 4x4 4 speed, step side that I'm doing a cab swap on. I the donor truck was an '67 F250 camper special auto tranny, so low hump. I'm gonna have to cut the hump out of the donor cab and install a high hump. I've found a high hump from a '79 f100....will this fit in my '67 just fine? Thx
Re: High tranny tunnel
It should be close , what's wrong with your original one.?
Well, nothing is wrong with it. I have this donor cab in my basement and want to go as far with it as I can before involving my truck. Since what I've seen is not too expensive I thought I might go ahead and get one, use it as a template to make the cut for the high jump.
- TNIceWolf
Best bet there is just use the bumpside tunnel.
you already have it and its not that difficult to use it. Saves you money and time for doing just a bit of work.
Presently in the stable
1969 Ford F-350 DRW
1969 Ford F-350 DRW
