Finally got the Kickdown Cable installed
- windhamdw
Finally got it on and it work perfect, i did have to get a longer bolt for the trans mount because it was to low.
Re: Finally got the Kickdown Cable installed
We call that " afro engineering"
1967 F-100 4x4 custom cab.
- colnago
Well done!
Joseph
Joseph
