steering wheel horn
patruccio
steering wheel horn
Post by patruccio »
I'm having issues with my horn, I recently bought a new steering wheel and horn ring.
The wheel fits perfect and looks great. The horn ring is a different cat, there is nothing under the
horn ring that has a metal surface to make contact with the brush assembly. I drop the brush assembly
in the hole and it seems to be way short for contact. I'm lost, any help would be appreciated.
Pat :help: I have a 68 Ford f250 2WD Camper/Special
colnago
Re: steering wheel horn
Post by colnago »
Can you post pics of what you have, showing the "innards" of the horn button, etc?
Joseph
bluef250
Post by bluef250 »
A longer spring on bush assembly may be needed.
71Fe2O3
Post by 71Fe2O3 »
There are two of the springy horn contacts, and you should be able to find a schematic on this site showing the internal anatomy of the steering column that will help you to get it together properly. As far as I know, the spring contacts come in only one size for these trucks.
Fred
1970 F100 4WD short bed, 360 engine, very rusty plow and yard truck
1971 F100 2WD long bed, 302 engine, on the road
1968 F100 2WD long bed, 360 engine, stripping for parts
patruccio
Post by patruccio »
Thanks for the reply's.
patruccio
Post by patruccio »
I found a longer spring for the brush assembly but there is no
metal on the retainer plate to make contact?
71Fe2O3
Post by 71Fe2O3 »
Have you checked the schematic to see if you have all the parts?
Also, do you know that your column is the original?
A previous owner may have put one in from a newer model that may have some different parts.
Fred
patruccio
Post by patruccio »
I have all the parts I purchased from LMC. I'm the 2nd owner and there
has been no alterations to the column.
patruccio
Post by patruccio »
:evil: I'd like to post some pictures but can't seem to resize them to email.
