66 Going back to stock, I hope...
66CustomCab
Post by 66CustomCab »
So this 66 F100 4 Wheel Drive had a ton of (really sub par) work done on it before I rescued it, including what I feel was an unwise lift.
Looking at the manuals, in the rear it shows a "spacer" between the spring seat and the spring. Question is, in stock configuration, how tall is this "spacer"? The one that is in there now is just shy of 7 inches tall, clearly adding to the overall instability of this lift. Need to get it back to stock, but can't find the necessary detail to tell me how tall this part should be.
Any thoughts?
eggman918
Re: 66 Going back to stock, I hope...
Post by eggman918 »
4" on the F-250 IIRC
Steve
Manny
Post by Manny »
66CustomCab wrote:So this 66 F100 4 Wheel Drive had a ton of (really sub par) work done on it before I rescued it, including what I feel was an unwise lift.
Any thoughts?
Yeah would have been a block your can change hangers and other stuff to eliminate them but they were in there from the factory 4 inch on highboy uncertain on the f100 :thup:
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
66CustomCab
Interesting responses, thanks. I found something that says the bed height (top) should be about 50 inches. Way above that now of course but you each mentioned something that gives me more questions to explore...
It appears some f250 parts may have been cloned onto this truck (like the 8 lug 16 inch wheels). At the same time is a mention of highboy... Factory/dealer option? How is that term defined? Is my assumption that some crazy aftermarket lift was done incorrect perhaps? :hmm:
cstoyer
Post by cstoyer »
So you have 8 lug axles on F-100 but originally they would have been 5 so can you identify which axles you have? Does you F-100 still have a coil spring front suspension?
cstoyer
68 F250 4x4
cep62
Post by cep62 »
cstoyer wrote:So you have 8 lug axles on F-100 but originally they would have been 5 so can you identify which axles you have? Does you F-100 still have a coil spring front suspension?
cstoyer
Do you have a divorced transfer case ?
Maybe you have a F250 with F100 badges ????
cstoyer
Post by cstoyer »
cstoyer
That is a good question.
68 F250 4x4
66CustomCab
ok, here is more..
The transfer case is D3TA7A195AA. Yep, 73.
New question; if placed in 4x2 mode, should the front driveshaft be turning when driving? Mine turns regardless of selection. Confusing as hell to this newbie.
cep62
Post by cep62 »
66CustomCab wrote: if placed in 4x2 mode, should the front driveshaft be turning when driving? Mine turns regardless of selection. Confusing as hell to this newbie.
You also have to unlock the front hubs.
If you don't have locking hubs , just a smooth cap , that axle came with a full time 4X4 T case (NP203)
And for a little more confusion there is a kit to convert a 203 to part time .
You should do an image search for NP (New Process) 203 (full time) and NP205 (part time)
Is there a drive shaft between the trans and T case , or is it mated to the transmission.
cep62
Post by cep62 »
Go to our home page tech section, there is a good article on T cases.
http://www.fordification.com/tech/transfercase.htm
66CustomCab
Thanks! That page on Transfer Cases did the trick. It is indeed an NP205. Clearly the handle in the cab simply listing 2WD or 4WD confused the heck out of me. Once I learned there are actually 4 positions rather than just 2, everything made sense.
cep62
Post by cep62 »
:thup:
