How do you protect your engine/parts from theft?
General Discussion Topic Archives
1968flareside
Post by 1968flareside »
My buddy had a chain and padlock on his 72. I just can't remember what/how/where he had it hooked up. I'm worried about the msd box and carb specifically. That is for quick, spontaneous thieves.
1968 F-100 Flareside
1999 F-150 XLT 4X4
http://www.fordification.com/galleries/ ... ?cat=10023
:fte: and :fr: DON'T FORGET!!
460 crew
Post by 460 crew »
I was thinking a cable with a llock looped through the hood somewhere and back down and locked wrapped around the frame, so I could unlock it right under the bumper?
Joe Kriston
re: How do you protect your engine/parts from theft?
Post by Joe Kriston »
The p.o. of my truck concocted something like 460 Crew described---and it was the first thing I removed....If I didn't throw it out you can have it---I keep my truck in the garage :D ...I can also send you my bad hood hinges with the worn springs--the ones that hold the hood up low enough so the thieves will bang their head on the latch every time they try to pull something out from under the hood....
mcarlson11
Post by mcarlson11 »
you can get a hood lock. I have one. I will see if I can get a picture of it. It goes around the latch and around valence area, I forget exacly how. Its very small, just a solid bar that is bent.
When the going gets tough, your doing something right.
Faithful Old Road Dog
Post by Faithful Old Road Dog »
I "threaded" a length of chain through the front of the hood channel. Then I lower the hood and bring the chain through the top of the latch hole and padlock it to the front of the center support bracket of the grill. Make sense? Maybe not, but it works fine as long as you don't have the 70 grill.
Jake11
Post by Jake11 »
12 ga
j41385
Post by j41385 »
:yt:
1968 F100 Took the running 390 out, and installed a Built 300 with AOD.
Engine Video... http://youtube.com/watch?v=2xgYd2u79NU
Image Image
pat67shorty
Post by pat67shorty »
When Mine had to sit out side during my bronco's V8 swap... I took a cable for locking up a bike, ran it through the hood bracing, down and looped around the frame behind the bumper. Then pad locked it.
I've been meaning to get one of those 12ga anti theft devices though... :lol:
'67 SWB, 1970 car 390, Edelbrock Streetmaster intake, MSD 6AL, 780 Holley, Hedman headers, 2.5 duals, 3.54 D44 L/S, C6.
BigRedTruck
Post by BigRedTruck »
I run a pretty good illusion of running on steam power
69 F-100 2wd 360 cid C6
surubet
Post by surubet »
Here's what I did years and years ago, although my lawyer said I could be sued. I super glued straight razor blades under the lip of the hood. It only took one week for the blood trail to show up and I didn't have anymore trouble after that and removed the blades with acetone. I even saw the neighbor from two blocks up the street with all the bandages on his fingers.
Naturally I had to remember not to cut myself to ribbons that whole time too.
1970 Ranger XLT F250 Camper Special, 2X4, 360, Factory A/C, 2 tone in greens.
binder56jd
Post by binder56jd »
chain & padlock :thup: :thup: jd
"Sell crazy someplace else. We're all stocked up here" — Jack Nicholson, As Good As it Gets
now serving #235
"the only way to believe in the American dream is to be asleep"--GC
How much easier it is to be critical than to be correct. - Benjamin Disraeli
DuckRyder
Post by DuckRyder »
:twisted:
binder56jd
S-man- that's a good idea!
DR- that'll work although i prefer the short barrel 12 ga w/ seven in the tube for up close& personal :lol: :lol: :lol: :lol: :twisted: :twisted: :twisted:
jd
now serving #235
LilJack
Post by LilJack »
Tie a large Pit Bull to the truck :twisted:
binder56jd
Get one of those rubber snakes and attach it in a likely spot :twisted: :twisted: :twisted: jd
now serving #235
