"C" bushings on the front diff
Chavezz
Post by Chavezz »
Hi can anyone tell me if im replacing the "C" bushings on the front diff. Do i need to use a spring compressor, thanks
rbmead
Re: "C" bushings on the front diff
Post by rbmead »
I would say yes. makes life much easier.
1972 Ford F100 SWB 4x4
Busboy
Post by Busboy »
Absolutely not, just set the truck up high with jackstands under the frame, put a floor jack under the front axle and drop her down.
1967 F-100 4x4 custom cab.
cep62
Post by cep62 »
You might want to loosen the front shocks.
