Hyperlinks???
Hyperlinks???
Why isn't there a add "hyperlink" option on the forum, I've never seen a forum without that option??
- Ranchero50
Re: Hyperlinks???
Re: Hyperlinks???
Yes I know how to do that but that's actually not a hyperlink. Hyperlinks can be added to pictures or words without showing the address.
Re: Hyperlinks???
I've never seen this type of forum tool bar, wasn't sure if it just wasn't turned on in the forum settings or something(?)
Here is the typical Hyperlink tool>>
- DuckRyder
Re: Hyperlinks???
You just use tags, the URL tag button gives you the method if you hover on it.
If you want to make text a hyper link, the put = and the url after url but before the first bracket and the text between the tags. So for instance if you use the following replacing the { with the appropriate bracket [ you will get the following results:
{url}www.rangerXLT.com{/url}
http://www.rangerXLT.com
{url=www.rangerXLT.com}my truck{/url}
my truck
my truck
