Hello all, I had another member contact me about wiring his f600 cluster to his 1970 dash harness.
Thanks to one of the fellow members who was able to figure out the debacle of the violet resistance wire. I made a diagram on the placement from the truck to the cluster. Hope this helps you all in your future endeavor.
Diagram for wiring the f600 cluster
- bluef250
Re: Diagram for wiring the f600 cluster
http://www.fordification.com/tech/image ... upanel.jpg
These diagrams show the same wire loom for the f100-350 as f-500 and up.
In one post, I remember someone saying that they had to switch 2 wires from the f100-350 to use the f-500 panel.
- hillcountryflt
this was much appreciated. It answers my challenge of the Black with red t racer wire. However, I have an orange with yellow tracer that I have not mated with one on the f100 side. Coming the other direction, there was this very "soft" grey wire (that seemed aluminum) that did not match with anything on the f600 side. An ideas there?
1971 F100 Custom SB Flareside;
2016 Explorer;
2020 F150
2016 Harley Ultra Limited
2008 Ford Mustang Deluxe V6
2016 Explorer;
2020 F150
- hillcountryflt
The orange with yellow tracer wire is not used on the cluster side, I discovered. Connecting the Red-green tracer wire to the violet wire provided the power I needed an most gauges work. It appears the alternator meter is not. But that is much progress.
2016 Explorer;
2020 F150
2016 Explorer;
2020 F150
