IF the emergency flasher switch is missing will this disable the brake lights? Because it is missing
I have a new brake switch and i can jump from the out going side of the switch to the brown brake wire and the lights work. But that feeds back to the dash lights and lights them up too. Is there a way jumper the switch harness or do i have more problems than that? Thanks for any help you can offer.
67 F100 Missing Emergency flasher switch
- jor
re: 67 F100 Missing Emergency flasher switch
No. The brakes will function without the E-flasher in place.IF the emergency flasher switch is missing will this disable the brake lights?
jor
ok. i'll start digging for the problem wire(s). I also did pick up a switch on ebay today thanks for the info.
