Looking to replace the radiator in my 68 F100, inline 6 240. Obviously it has a rather small radiator opening. Does anybody make a quality aluminum radiator that would fit in such a narrow opening or would it be beneficial to fit a v8 sized radiator instead? I do live in Florida so the additional cooling would be appreciated.
Thanks.
Inline 6 Radiator Options
Re: Inline 6 Radiator Options
You might want to check with Champion Aluminum Radiator: https://www.championradiators.com/ to see if they have one that would fit or other suggestions. They do carry them for our trucks, you can see some reviews on Champion if you type Champion Aluminum Radiator in the search area of our website. Summit, Jeggs, ebay would be good places to look for best price.
Good luck, and let us know what you find out
Regards
Regards
According to this Fordification fact sheet, you will have to make some modifications to your radiator core support for the V8 size radiator to fit:
http://www.fordification.com/tech/inter ... iator_core
Regards
Regards
I ended up going with a Champion radiator designed for a Chevy V8 swap because it places the inlet/outlet on the correct side for the inline 6. I’ll just have to trim the sheet metal but all the holes are there for the larger radiator.
Thanks for the feed back! Good to know what worked for you.
Regards
Regards
