Dome light won't turn off with fuse in fuse block.
nettak49
Post by nettak49 »
I went to replace the fuse for the dome light/cigar lighter on my 1970 f100 and found that there was no fuse. When I put a fuse in, the dome light is constantly on. I checked the headlight switch to make sure the dome light wasn't turned on there. I checked the door switch to see if the dome light would go off with it pushed in. I assume the previous owner pulled the fuse because the light would not go off. What can I check to fix this issue? Could it be a problem with the headlight switch itself?
My toys: 1970 F100 XLT, 302; 2018 Harley Davidson Fatbob; 2016 Toyota Tundra
cep62
Re: Dome light won't turn off with fuse in fuse block.
Post by cep62 »
That would be a good place to start.
Here's a 69 wire diagram that may help.
http://www.fordification.com/tech/wirin ... lights.jpg
Or someone in the last 50 years could have cobbled something too.
DisneysPatB
Post by DisneysPatB »
Switch or door buttons, Start with switch.
1972hiboy
Post by 1972hiboy »
DisneysPatB wrote: Sun Nov 13, 2022 10:20 am Switch or door buttons, Start with switch.
x2 :thup:
Rich
Dont eat yellow snow.....
basketcase0302
Post by basketcase0302 »
Dual post, see my reply on your other thread. :wink:
