Ignition Switch Upgrade
Gray035
Post by Gray035 »
I'm considering upgrading my 68 ignition switch (round terminals) to a later model ignition switch (bladed terminals).
I purchased a later model switch and pigtail, but the pigtail wired are all like 16 gauge wire, whereas several of the wires on my original switch are much larger gauge and correspond to larger round terminals.
Has anyone done an upgrade like this? What did you do about the mismatched wire gauges?
Also, does anyone have a wiring diagram for these switches?
1968 F-250 Camper Special
cep62
Re: Ignition Switch Upgrade
Post by cep62 »
Go to our home page.
Then diagrams and schematics , there are some wiring diagrams there.
Jbarnes79
Post by Jbarnes79 »
The later model switch most likely has the smaller gauge wire to control a relay which takes a lot less power. If you are going to try and put the larger wires onto the later model switch, without upgrading to relays, you will probably burn it up.
http://fordification.com/forum/viewtopic.php?t=67810
1969 F250 4x4
1969 F250 Crew cab (Sold)
1972 F250
1969 & 1970 Mustang
