heater hose question
larry499
Post by larry499 »
Would someone please tell me which heater hose goes where on the outlets on the firewall? I failed to note position when I took everything apart. Thanks, Larry
jor
re: heater hose question
Post by jor »
The outboard hose has the heater valve in it and routes to the intake. The inboard hose goes to the water pump.
jor
larry499
Post by larry499 »
jor, Thank you,blue oval guru. I marked all the control cables, got all the flapper doors resealed and back where they went only to discover I had not done the obvious. Larry
