Kieth (and all you lurkers),FORDification wrote:Don't worry...you're fine, just razzin' ya!
Actually, it's been my experience that the saddle tanks don't have a sending unit....they're for storage only. Here's a couple pictures of the dealer-installed saddle tank from a '70 CS I parted out a while back:
http://www.fordification.com/images/Ueh2_70CS01.jpg
http://www.fordification.com/images/Ueh2_70CS02.jpg
The factory auxiliary tank setups that I've seen had the switch under the dash with a bezel marked for the main and auxiliary tanks, pictured below on the right side. However, I have run across a bezel that is marked 'L' and 'R' for left/right tanks (at left in pic below), which I can only assume is for a saddle tank kit...a different variety than what's pictured above, with tanks set up with a sending unit. However, since there's no 'main' setting on that bezel....I'm thinking it's part of the dealer add-on tank kit, and the kit would include a new three-way electrical switch, with the middle position being the main tank. Can anyone else shed some light on this?
I had the gage switch marked L/R on my 70 F-250 with three tanks- the main in cab tank and two saddles. The switch is labeled L/R but is actually a THREE position switch (L/R/middle), with the middle being the main tank.
The setup looked like a very professional install. Who knows what the PO was thinking??
