insided door handle installation
- 1971ford
I painted my panels and am trying to get the drivers side interior door handle back on. I got the passenger one on and working easily but on the drivers side i cant get the little bar that comes from the handle to go under the bar attached to the opening mechanism. any tricks to get this installed? right now im using a screw driver as a door opener
-Ryan
- 1971ford
- 1971ford
yeah. ill try to make it more clear
there is a small metal peice coming from the interior door handle itself that is about 1 inch long and maybe a cm wide. this peice needs to be placed under a pole that is inside the door for it to work. I cant get the metal piece coming from the handle to go under the pole coming from inside the door.
hope that helps
hope that helps
-Ryan
- 1971ford
well the pushing of the exterior didnt work and the tightening of the nuts didnt work but when i was out there i remembered how i did it before. there are holes cut in the bottom part of the lever assembly. i put the lever on and stuck a flat head through the hole and lifted the rod up so i could get the lever rod under it.
-Ryan
