painless wiring harness install
tybob81
Post by tybob81 »
I started to mount and route my new painless wiring harness for a 67-77 ford truck.
Finleyphoto
re: painless wiring harness install
Post by Finleyphoto »
Are you using a resistor to the coil from the ignition switch?
Trying to help another member out with his wiring.
I like that distributor you got there. Which one is it?
Thanks - Dennis
Check out my Photos on Webshots at...
The Whiskey Flats Farm & Implement Co.
http://good-times.webshots.com/album/560836732OwHRTB
