'68 F100 Ranger Column shift knob question.
03rangerxlt
Post by 03rangerxlt »
Does the shift knob on the column shifter just press fit onto the shifter, or is it supposed to thread on?
-John
1968 and 2003 Ford Ranger
"Honey, how 'bout I lock you up on charges of aggrevated dumb slut with no future?"
-Det. Ray Carling "Life on Mars"
"Criminals thrive on the indulgence of society's understanding."
ezernut9mm
Post by ezernut9mm »
it is pressed. there are spines on the shifter. don't ask me how to get the knob off without destroying it though.
1971ford
Post by 1971ford »
yeah, those things are on there solid. good luck getting it off in one peice :eek:
i got a question...
how do you remove the shifter as a whole?
-Ryan
cruzerman350
Post by cruzerman350 »
1971ford wrote:yeah, those things are on there solid. good luck getting it off in one peice :eek:
i got a question...
are you talking about the shift lever and the collar? if so you have to pull the steering wheel and then i believe you pull off the turn signal switch if you can get enough slack out of the wires, if not you have to cut the wires at the bottom of the column and then fish them back through after your done. its pretty self explanatory once you get the steering wheel/hub off. i learned this the hard way because my shift collar was broken when i bought my truck. oh by the way i have a 67 f-250 so it may be different depending on year and models and whatnot.
hope that helps
-miles
03rangerxlt
Aight. My ass became a drunk ass making a special shifter column knob for my '68 using a shift knob ordered from LMC and a .50BMG round. Hopefully will beable to get a pic up soon-ish.
-John
