4.56 dana
- 19674x4
4.56 dana
does anybody know what rpm's the dana 60 with 4.56 runs, that is what i have and wondering if i should switch to a lower gear for gas mileage
My Photo Album
- heep70
Really high!!!! If you want milage then yes you should go to a taller gear. 3:73 or 3:54
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- willowbilly3
re: 4.56 dana
Depends on your tire height. My actual experience is a little different than most people. I haven't found the lower gears to be that much worse on mileage but the higher rpms do wear out the engine faster. I have had several highboys with 4.10 gears and got around 13 mpg on all of them, back when gas was good. I also had a 57 F-350 with a 312 and a 5.13 gear. I rwan it 65 all the time, not sure of the rpm but after about 30,000 it was starting to use a little oil.
- roachrider
re: 4.56 dana
willowbilly is right. It really does depend on the tire height. I had 35's on my '67 until recently and I've got 4.56's front and rear. My highway RPMs were only about 2750 @ 60MPH. Before when I had 37's, it was even lower.
Althought, with that said, if you've got stock size tires, your RPMs will be pretty high with a direct drive tranny.
Thanks,
-Aaron Taylor aka...Mr. Winch
1967 F-250 HiBoy - 352ci, NP-435, Dana 24, Dana 44 & 60, 4.56's, Riding on BFG 35's
1982 KZ-1300 - 650 pounds, 120+ HP, 85 MPH Speedo
- 19674x4
iv'e got 33 inchers
My Photo Album
- 68F250
re: 4.56 dana
Here ya go:
mph...rpm
50.....2321
55.....2554
60.....2786
65.....3018
70.....3250
75.....3482
mph...rpm
50.....2321
55.....2554
60.....2786
65.....3018
70.....3250
75.....3482
Barry
- 19674x4
re: 4.56 dana
wow, thanks, looks like i will be on the lookout for some lower gears
by the way, does aybody have a gas pedal i could buy
i seem to have broke mine somehow
My Photo Album
