tss wiring on 68 bump side
elky1349
Post by elky1349 »
the colors from tss are
green/orange
orange/green
blue/yellow
green/white
white /blue
light blue
green
the other endis as like this
red,black are together
light blue/yellow
green,white are together
white,blue are together
there u go fordman :help: :pray:
Re: tss wiring on 68 bump side
besides what you saw from the kapt. here is what i have at my place. and then there are the links to the 69 wiring harness. http://www.fordification.com/tech/wirin ... _81-85.jpg
alot of those are same color plug ins. the red black wire 810 is brakes and main power through the tss. now the two green whites is strange. so you will have to just test them to see which one is correct. the horn is going to be blue and blue yellow hooked together. lets see how far that can get you.
here is a picture of the 67-69 wiring coming either out of the dash or the column. this si the best i can do. now that i am getting this redirect thing fixed.
