Letter mounts
hotrod ford
Letter mounts
Post by hotrod ford »
I am in need of some hood letter mounts. Just mounts, not the letters. Thanks
Bob
Re: Letter mounts
Post by Bob »
Aren't they just speed nuts on the back of the letters? 99.9% sure that's how mine are attached. Pins cast into the letters that poke through and a speed nut spun on.
hotrod ford
Re: Letter mounts
Not sure what the are called, but the only one I do have does not look like a nut as one would go on a bolt. Can't find them in catalogs, have to buy the letters as well.
Bob
Re: Letter mounts
Post by Bob »
Have a look at these...
It'll either be speed nuts like these...
http://www.mcmaster.com/#spring-speed-nuts/=h6cog8
Or maybe barrel clips like these...
http://themustangshop.com/catalog/catal ... oryID=1503
jzjames
Re: Letter mounts
Post by jzjames »
I put blobs of silicone on the tabs that stick through. Holds them on and seals the hole.
hotrod ford
Re: Letter mounts
Yep, those barrel clips look like the one that I do have. Thanks for the info.
