Tom did a great job on the column, however being the turn signal switch is from a 69, the colors on the wiring are a bit different and I cannot seem to locate the proper connections hence the signals/brake lights are not working properly...anyone have a hint for me as to how I can fix this? The truck is a 70 and the harness from the truck has a yellow wire that the 69 harness does NOT have....perplexed...
