ISO Autolite 2100 1.08
Private parties only. No eBay/Craigslist listings.
Effie_70
Post by Effie_70 »
or equivalent...trucks been down two weeks need a carb...talk to me! Thanks! :thup:
Effie_70
Re: ISO Autolite 2100 1.08
Post by Effie_70 »
anyone have a lead on one?
Effie_70
Post by Effie_70 »
never mind
Effie_70
Post by Effie_70 »
forget it lol thanks
1972hiboy
Post by 1972hiboy »
BUmmer I missed the post. I could have whipped up a nice one for your truck. Glad to hear though. you rolling again?
Rich
Dont eat yellow snow.....
Effie_70
Post by Effie_70 »
1972hiboy wrote:BUmmer I missed the post. I could have whipped up a nice one for your truck. Glad to hear though. you rolling again?
nope...after rebuilding the column/shifter she was...then BANG literally...backfired...NO START! I am thinking I slipped time and lost timing chain/distributor...will have to look at it in two weeks when I return from Cali...look in ENGINE forums.
1972hiboy
Post by 1972hiboy »
I will be sure to check out the thread pertaining to your engine not running. I hope you enjoy your time in cali :wink:
Rich
Effie_70
Post by Effie_70 »
thanks...its a business trip but I will certainly try!
Effie_70
Post by Effie_70 »
working on it this weekend...replacing timing chain and gears, water pump has new Autolite carb, coil, HEI distributor and battery...the timing chain slipped three teeth and sheared a couple off...wish me luck!! Shes been down soo long....
Effie_70
Post by Effie_70 »
OK soo.. timing chain and gears replaced...timing set 10 btdc...new carb, water pump and HEI distributor and coil...got it running but will not idle, as soon as u take foot off gas stalls. I HAD two vacuum ports on the old points distributor and only one on the HEI dizzy...which one to connect? Also, after she stalls she spurts gas out of the carb...anyone assist me with some adjustment advice?
1972hiboy
Post by 1972hiboy »
After changing that much stuff sound like you have a few problems compounding themselves on you. first off though, gas spruting out the top of the carb ususally means the float is stuck. Try tapping on the front of the carb where the fuel line goes into it with a rubber mallet of a cloth wrapped small ball peen hammer and see if that shakes it up enough. thats why your truck is dying when you let off the fuel its flooding big time. You only need one vac line going to your new hei. for now connect your vac line from the distributor to the vacuum port that is higher up on the passenger side of the carb. this is timed port vacuum. and plug off the port at the baseplate and try starting it again.
Rich
Effie_70
Post by Effie_70 »
1972hiboy wrote:After changing that much stuff sound like you have a few problems compounding themselves on you. first off though, gas spruting out the top of the carb ususally means the float is stuck. Try tapping on the front of the carb where the fuel line goes into it with a rubber mallet of a cloth wrapped small ball peen hammer and see if that shakes it up enough. thats why your truck is dying when you let off the fuel its flooding big time. You only need one vac line going to your new hei. for now connect your vac line from the distributor to the vacuum port that is higher up on the passenger side of the carb. this is timed port vacuum. and plug off the port at the baseplate and try starting it again.
Thanks guys! SHES RUNNING!! See my post in the ENGINE category... :woohoo:
