Hello, I have a 67 250 with a 12v cummins, nv4500, and divorced 205. I still have to factory Dana 44 closed up front and just purchased a 78 250 for $1900 to get the Dana 60 from it. From my research it's almost a direct swap. I'm just second guessing myself because I am kind of falling for this 78 250 and really don't want to chop it up and scrap it because it's a good runner and everything is there. Can I just put the Dana 44 closed under the 78 and roll with that? I'd imagine it would fit if the 78 Dana 60 is nearly a bolt inwhat should/could I do about this axle swap?
1967 f250 6bt Cummins, Dana 60 front, 14 bolt rear, np205 divorced.
1985 Mustang SVO Sage green, big turbo, aluminum big valve head, 03' Cobra IRS.
1986 Mustang SVO medium caynon red metallic, Stock
- 1972hiboy
Re: what should/could I do about this axle swap?
You sure the f250 came with the hpd60 in the front? I thought that was a f350 thing? maybe if the truck has the snow fighter package. I dunno man, personally a nice extended cab truck like that id hate to butcher up and start swapping out parts on it.
Rich
Dont eat yellow snow.....
I'm pretty sure. I researched until my eyes bled. I came up with 76+ Dana 44s all came with ball joints. This truck is a 78 with a king pin axle. I haven't gotten a chance to look at the numbers yet. I saw that 78 f250s had the option of the snow fighter package and you could also upgrade the axle without the snow package. I measured the locking hubs to be at or about 4 inches in diameter as said the Dana 60 hubs measure to. My Dana 44 closed knuckle hubs are about 3 inches. There are 4 bolts holding the steering arm over the king pin.1972hiboy wrote:You sure the f250 came with the hpd60 in the front? I thought that was a f350 thing? maybe if the truck has the snow fighter package. I dunno man, personally a nice extended cab truck like that id hate to butcher up and start swapping out parts on it.
