Glove Box
- 69Ford
Re: Glove Box
Here's what you need. The plastic piece put through the spring and pops into a hole on the right side of glove box on dashboard. I have looked high and low for the plastic part aftermarket. You can find the glove box bumpers and the spring just not the spring retainer. So grab them when you are at a pic & pull
Re: Glove Box
Thanks for the info I will start looking for the retainers.
Re: Glove Box
Hmmmm
I wonder if something like this would work? Adjustable for height/thickness. Click it together to compress the spring just a hair and then put a drop of Super Glue on it so it doesn't move.
Re: Glove Box
You don't need any type of auxillary spring. The latch itself pops the door open when released. Either thoroughly clean and lube the existing latch or buy a new one from NPD or many of the other suppliers.
Re: Glove Box
Make sure the glove box door is aligned and opens freely, not hanging .
