Help I'm new to the site
Hello everyone I have a 67 f100 that I'm installing a 390 fe in. It had a old 390 in it that was in rough shape I pulled it out and it has a c6 automatic trans but when dropping it in the flex plate keeps binding and not allowing the motor to go back in place and sit on the mounts any advice?
Re: Help I'm new to the site
![Welcome :wel:](./images/smilies/icon_welcome.gif)
Welcome to the site.
There may be a couple things.
Make sure a pilot bushing from an old manual trans isn't in the end of the crankshaft .
I'm not sure about the FEs but the 429/460 used different pilot sizes on the torque converter , double check that.
And what I like to do is get some 7/16 bolts (coarse thread) and cut the heads off and cut a slot in the end ,
and use them for aligning pins for the bell housing.
Use a jack to get the front of the tranny up.
Make sure the fly wheel lines up to the torque converter studs.
Try that and check back in.
- popeyes71
-Popeye-
1971 F-250 4x4 Highboy
- Mancar1
Welcome aboard from Gerber, Ca.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Alright guys thanks for the replying so I got one motor mount that's taller then the other the 390 I took out fit though I will get some pictures for yall too look at but why the shorter mount on passenger side though what do yall think?
OK guys I got the motor back in the old truck but I have another issue that I need some help with the trans cooler line are right under the header reducer on passenger side what's the best way to deal with this issue any help would be great.
