The 70 crew's progress-modifications and cummins swap
- 460 crew
Re: The 70 crew's progress-modifications and cummins swap
I’d have to get some tomorrow, but yes they sit way too high for most people but fit me ok. I’ll probably change them in the near future.
- popeyes71
Sounds like you still have your truck, thats great! I liked following your build! Did you get the front end dialed in? You had mentioned that your son was building a highboy, how did his truck turn out?
-Popeye-
1971 F-250 4x4 Highboy
- 460 crew
Brett
The channel is 1.5in and only on the outside, as you probably noticed the cab is lower on the outsides so that makes them flat. To be done properly all the feet of the seats need to be modified but like I stated they work ok for me at 5’8” and give me better vision
Popeyes71, yep still have Hunka.....progress has been a different story. I’m currently work on the engine rebuild and then the front suspension will be finished up. One thing is always hinging on another for the most part.
I did similar with 1" square tube. Im thinking of cutting 1-1/2" off inside, towards middle, seat bracket and welding in an angle iron so outside sits and mounts flush to original floor. At 5`10" I can make what I have now work but think a little lower would be ideal. Thanks for sharing. Makes me feel better about what I came up with seeing that's how you did your seat install.
Brett
77 f150 5.8 4wd
00 f250 7.3 4wd
18 Raptor
77 f150 5.8 4wd
00 f250 7.3 4wd
18 Raptor
