hfdco4
Posts: 1324 Joined: Mon Apr 01, 2013 1:45 pm
Post
by hfdco4 » Sun Oct 31, 2021 9:34 pm
Paul
FE390PC
1970 F250 4x4
2016 F150 4x4 2.7 ECO
Gone 1988, 1989 & 1991 Broncs
hfdco4
Post
by hfdco4 » Sun Oct 31, 2021 9:36 pm
cab on frame
Paul
FE390PC
1970 F250 4x4
hfdco4
Post
by hfdco4 » Sun Oct 31, 2021 9:38 pm
As it sits today after a lot of cleaning
Paul
FE390PC
1970 F250 4x4
Fordkid68
Posts: 313 Joined: Fri Oct 16, 2020 7:27 pm
Post
by Fordkid68 » Mon Nov 01, 2021 5:30 pm
Looking great!! You'll be driving it before you know it!
Adam
My first truck,
^^Build Thread^^
(no other projects, YET!)
hfdco4
Post
by hfdco4 » Sat Nov 06, 2021 6:33 pm
Plenty more work to do, but thanks for the motivation. I am going to assemble the front of the engine so I can get the 3G Alternator and Power Steering Pump mocked up. Spent a little time on the daily doing some needed maintenance.
Paul
FE390PC
1970 F250 4x4
67mann
Posts: 1706 Joined: Thu Feb 07, 2008 7:19 am
Post
by 67mann » Sun Nov 07, 2021 10:14 am
hfdco4
Post
by hfdco4 » Sun Nov 07, 2021 8:07 pm
Got some more cleaning done. Managed to make a fairly large pile of scrap going now. Also got the center top portion of my old core support cut out. I am going to graft it into my 78 core support.
Paul
FE390PC
1970 F250 4x4
LeoZelig
Posts: 136 Joined: Fri Aug 01, 2008 4:31 pm
Post
by LeoZelig » Wed Nov 10, 2021 10:22 pm
Paul, congrats on the milestone! That's gotta feel great!
Hey, did you build the gantry/block and tackle frame for lifting the cab, yourself?
hfdco4
Post
by hfdco4 » Thu Nov 11, 2021 8:58 pm
LeoZelig wrote: Paul, congrats on the milestone! That's gotta feel great!
Bought it at Harbor Freight, it works great!
Paul
FE390PC
1970 F250 4x4
LeoZelig
Post
by LeoZelig » Sun Nov 14, 2021 12:47 pm
hfdco4 wrote: Bought it at Harbor Freight, it works great!
Harbor Freight, my new home away from home
That's good to know - someday I'll need that kind of gear to take the truck apart.
hfdco4
Post
by hfdco4 » Sun Nov 14, 2021 7:59 pm
I like HF, you just have to look at what you are buying. They have the super cheap and useless tools as well as inexpensive good tools. I have an engine crane, engine stand, floor jack, the gantry crane and chain fall. I use all of them and they work great. I have also bought jack stands there but never the recalled ones.
Paul
FE390PC
1970 F250 4x4
hfdco4
Post
by hfdco4 » Mon Nov 29, 2021 10:44 am
Got some more of my hoarded parts cleaned. I was looking at the axles and realized I only had half of the U-Joint U-Bolts ready to go. I found my container of spares and dumped then in the EVAPO Rust for cleaning. Next is the flipping of the Front Axle U-Bolts. I went to the swap meet in PA and found a set of U-Bolts and Plates.
Paul
FE390PC
1970 F250 4x4
LeoZelig
Post
by LeoZelig » Mon Nov 29, 2021 10:10 pm
hfdco4 wrote: I found my container of spares and dumped then in the EVAPO Rust for cleaning
I found EvapoRust just before starting this latest project - I love what it does for our old, rusted bits and bobs!
It sounds like I need to start searching out swap meets, too
hfdco4
Post
by hfdco4 » Tue Nov 30, 2021 7:56 pm
It is a good place to find odd things.
Paul
FE390PC
1970 F250 4x4
hfdco4
Post
by hfdco4 » Tue Dec 07, 2021 8:31 am
I have the last U-Bolt in the evaporust solution now. Hoping it is cleaned up in the next day or two. Then hoping to get them installed this weekend!
Paul
FE390PC
1970 F250 4x4
