Thanks! And yes...I used 3M's spray adhesive.sargentrs wrote:I agree with Terry...looks great! How did you install it? Spray on adhesive? Great job! Thanks for the pics.F100builder wrote:terry1167 wrote:Looks totally awesome.I recently put down a few layer of sound dampner (Zillamat), foil back insulation, and sound barrier. I also wrapped the cab, doors, and ceiling. I am hoping to get my carpet towards the end of the month and install it. Thanks for the pics!
Thanks Terry! Lookin' good on yours too! Keep it up!
Lizard Skin is good stuff for sure but a little pricey for this go around. My '69 remains to be my low-budget beater until I get my '56 finished. Once that's done, I will revisit the '69 for some improvements and perhaps a complete ground up restomod build.CommrclDiver wrote:Well I don't know if I'm too late or not but Lizard Skin makes a great sound deadener/heat shild that sprays on at a mear .040-.060 thickness. It's also water soluable so it cleans up easy. Here's the link to Summit Racing where I got mine.http://www.summitracing.com/parts/LIZ-50100/ Just my![]()
It is the stuff but I don't walk around in my truck!red403 wrote:f100builder......that is the stuff that is foil on both sides with little air bubbles in it correct? I wonder how long the air pockets will last when you walk on it.
How many water heater blankets did you need to buy to do the floor? How did you apply it to the floor? Just laid it in place or did you use some type of adhesive?
do you remember what the insulation product that you bought?terry1167 wrote:I didn't use the water heater blankets but I did use a variety of insulation products and I did use the spray adhesive to hold it in place plus I wanted it pretty tight to the floor and contours because I was putting down new molded carpet. The spray adhesive works good.
