Forest Service Truck Coyote Swap
Re: Forest Service Truck Coyote Swap
I just need to finish the inner cab corners, but the rust is removed for now. I'm guessing it will hold together for another 50 years. The drivers door has some and the rear bed under the tail light, but that is part of the patina! I'm saving those to remind myself how enjoyable rust repairs are and stay off ebay! LOL
Another full day to fab these little pieces. Not really sure if thats how it was originally, but it will work for this truck.
Same for drivers side. Seam sealed inner welds and sprayed some weld through primer.
Getting busy now that its summer here in Wisconsin. It is so damn short you better do a few things or its back to winter before you know it. I got the inner cab corner panels welded in. Need to clean up bottom of truck and paint it next.
- hfdco4
Really good work on making poor quality parts fit.
Paul
FE390PC
1970 F250 4x4
2016 F150 4x4 2.7 ECO
Gone 1988, 1989 & 1991 Broncs
1970 F250 4x4
- Fordkid68
Awesome work!! Looks great!
Adam
My first truck,
^^Build Thread^^
(no other projects, YET!)
My first truck,
^^Build Thread^^
I got body work all finished up. I cleaned, sanded and epoxy primed bottom of truck. Next seam seal, 2K primer and topcoat.
Two coats 2K primer and two coats top coat forest service green.
- Fordkid68
AWESOME!!!! Looks great!
Adam
My first truck,
^^Build Thread^^
My first truck,
^^Build Thread^^
Finished painting. The exterior still needs a Mat clear coat at some point. Started installing gas tank. Cut lower frame rails and moved cross member to the rear. I am going to hang the tank with stainless steel straps so it can be serviced without pulling bed.
Cleaned, prepped and painted remaining part of frame. Installed cab which is some welcome progress. Need to install front clip and bed to get everything aligned to drill front cab mount holes.
- Fordkid68
Amazing work! It must feel great to start putting things together after all that metalwork!
Adam
My first truck,
^^Build Thread^^
My first truck,
^^Build Thread^^
Thanks Adam!!
- hfdco4
Great progress, this is going to be a real head turner soon!
Paul
FE390PC
1970 F250 4x4
1970 F250 4x4
Mustang 22 gallon fuel tank installed with stainless steel straps. I wanted tank serviceable without having to remove bed so it tucks up tight to bottom of frame.
