I'm using a new MIG welder to weld in patch panels and for general rust repair on the cab of my truck...but I'm having some major problems. Here are the specs and materials I'm trying to weld with:
- Hobart Handler 175 (set Electrode Positive for solid wire)
- ER70S-6 (.024) wire
- shielding gas (75% Argon, 25% CO2), set at about 30# pressure
- Voltage setting 1 (as low it will go)
- Wire speed - about 45
- app. 1/4" stick-out
I tried welding up the gas tank filler hole in my cab last weekend as practice for getting started on all the rust repair, but I was completely embarrassed about how it turned out. In fact, I wasn't even going to post these pictures, but decided to bite the bullet and do it anyway...I mean, I want to do this right, and while I might cause a few of you out there to chuckle at this butcher job, if you can give me some tips and pointers about how I can do things differently, I can handle it.
The problem is that I can't seem to NOT burn through the metal. Almost immediately upon touching the metal, it burns through. It's like the voltage is just set too high...but I've got it turned down as far as it will go! I know that you have to hit a balance between voltage and travel speed, but I'm not even getting a chance to start moving before it burns through.
When I started burning holes, I then tried to just hit and miss very quickly to basically fill the hole. I figured I could grind it down later to be invisible. I didn't take any pictures BEFORE grinding it down (it was too gruesome to look at), here's a shot taken after grinding it down:
It doesn't look TOO bad in this shot, but you can see that it ain't pretty. However....here's a view of the backside:
Before I do any more welding on the cab itself, I'm going to be cutting up an old door skin to practice more butt welds on. But I was hoping someone could give me an idea or two about what I'm doing wrong and how to improve it. I'm not after a pretty weld, since it'll be ground down smooth anyway....but I DO want good even penetration.
I bought this welder a couple years ago when I was working on a Studebaker truck project, because I needed something capable of welding thicker metal, since I was going to have to shorten the frame. However, the Stude project got sold when I decided to do this Ford instead, before I even got a chance to fire the welder up, and so this is what I have to use. So did I just buy TOO MUCH welder??
Any thoughts or suggestions would be appreciated. I'm also going to be posting this message and pics to the Hobart Welding Talk messageboard in the hopes that some of the experts there can help me out.
