The unit I got is a 40 Lb Central Pnuematic, and it is awesome! I just can't wait to get started on the cab!
I have posted the following question in the body an Paint forums:
http://www.fordification.com/forum/view ... =9162#9162
Ford390pwr wrote:I recently picked up a really neat Sandblaster because it took me over 3 hours to clean up an old door panel with my siphon feed gun! Anyways, I just had to fire it up and see how it worked, and I must say woohoo!![]()
I know with my unit from Harbor Freight, there was a lot of assembly required! Maybe there is some kind of an obstruction causing one of the valves to be restricted. I would probably start with the valve at the bottom of the tank and ensure that it is not clogged. Maybe remove the hose that screws into the back of that and see if the air flow at that hose seems to be unobstructed?MAK wrote:Any ideas? Thanks
Mark
shrektruck wrote:Mark,
You should have 3 valves on the pressure pot that should all be open for proper operation. Number 3 can be adjusted to regulate the amount of sand. I have found that the finer the sand the more likely it is to clog.
Don't forget to check the rubber gasket at the nozzle to make sure it's not blocking the orifice.
