Wipers
theogre5150
Wipers
Post by theogre5150 »
Ok....just replaced my 2 speed wiper motor and it works fine. The only problem is that they will not shut off. I have to position the switch in between the speed settings. Is this a bad wiper switch?
mrsnicks
Post by mrsnicks »
Silly question, and I'm not sure if it's right without looking at my truck. But did you ground the new switch?
I "think" it has a ground, and did you remember to re-ground it on installation?
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
theogre5150
Only replaced the motor. The switch is the original.
Blue Cloud
re: Wipers
Post by Blue Cloud »
you might have gotten a bad motor. I never had one do that before.
wt4speed#2
Post by wt4speed#2 »
mrsnicks wrote:Silly question, and I'm not sure if it's right without looking at my truck. But did you ground the new switch?
Patrick
This was probably refering to the intermttent upgrade , thats what I thought until I reread your post . What kinda symnptoms where you having proir to replacing wiper motor?
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
wt's ride
thebucket
Jake11
re: Wipers
Post by Jake11 »
Theres a park switch in the motor. It might be bad.
theogre5150
The motor I replaced would hum and barely move the arms, but the motor would turn off with my current switch.
theogre5150
I was talkin with a buddy of mine and he said to swap the red and blue wires. He said that it may change the sequence but should be able to turn the wipers off.
theogre5150
Ok....so here's what I did. Both the wiper motor and switch have four wires coming off of them. Black, white, red, and blue. I tried some different combinations and it works fine when you unhook the red. I taped it up and now I can turn my wipers off. Thanks for the responses on this.
FORDification
Site & Forum Admin
Site & Forum Admin
re: Wipers
Post by FORDification »
Here's what the factory shop manual says about your problem:
[img]http://www.fordification.com/board/wipe ... lpage].jpg[/img]
theogre5150
Hey Keith.......am I going to have a problem later on with the way that I wired up the motor?
