whats the best way to power my accessories, such as elec fuel pump and fan. can i run them right from the "key on" side of the starter solenoid? i ordered a white rodgers power solenoid (70-111224-5), anyone ever switched to one of these.
thanks
THATCH
power accesories
- THATCH
- Thunderfoot
re: power accesories
You will want to use a relays using the battery power, you can use the ignition wire for the trigger source to "activate the relays"
The wire on the solenoid is for activating the starter, and the other is for boosting the voltage to the coil when starting (you could probably use this for the trigger wire for the relays as it is connected to the coil wire)
