I have been reading the section on coverting a 4WD to power steering. I found this one at a salvage yard. I'm not planning on using since my truck is a 2WD, but I wanted to make sure it was 4WD only before I passed it up.
Is this a power steering box for a 4WD? (pics included)
Moderator: Doug Comer
- JWW
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
2004 F150 Crew Cab
re: Is this a power steering box for a 4WD? (pics included)
Good eye. That looks to be a power steering box from a half ton becuase of the coil spring front suspension. I'm sure somebody is actually looking for that box. Doug
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
X2 on the 1/2 ton.
Looks almost identical to the one I got from a 79 Bronco.
It does however appear to be just a tad longer up and down though.
67 HiBoy - 390/435/TS'd205 HPD60f/FFD60r welded 3.54's 36x12.50x16 TSL radials
50 Willys P/U (project) - 302/435/205 FFD60r
- averagef250
That's the 76-79 F-150 4x4 box.
The casting number you posted is off the torsion valve assembly. It reads as a 67 part number because the valve is the same from 68 through 97.
These boxes are a popular swap for EB's and obviously F-100 4x4's. Most swaps require you to swap out the ballnut for one that works in the opposite direction.
